So I'm going through my undergraduate in EE. Needless to say, 90% of the work we do is theoretical. So when I'm going to actually build stuff in real life for my own fun, I'm having trouble finding information I need. One problem I've ran into is using a darlington array. Here's the datasheet:
http://www.datasheetcatalog.org/datasheet2/b/0fxyuf66ess3kw8eaxa6ueweq7cy.pdf
I don't see anywhere in the parameters what the common pin should be set at which voltage. For my application, emitter is grounded, but I'm assuming the common pin needs a specific voltage (its probably 5v) but I don't see where anywhere on the datasheet. Can someone help me out?
