I need to correct the code Arduino
Code:
#include <OneWire.h>
#include <SoftwareSerial.h>
int DS18S20_Pin = 2; //DS18S20 Signal pin on digital 2
//Temperature chip i/o
OneWire ds(DS18S20_Pin); // on digital pin 2
SoftwareSerial mySerial(11, 10); // RX, TX
unsigned char data[4] = {};
float distance;
void setup(void) {
Serial.begin(57600);
mySerial.begin(9600);
void loop(void)
sketch1();
void sketch1( void )
static unsigned long startWait = 0;
static const unsigned long waitMillis = 3000;
if ( millis() - startWait >= waitMillis ) // now - start == elapsed time so far
do {
for (int i = 0; i < 4; i++)
data[i] = mySerial.read();
} while (mySerial.read() == 0xff);
mySerial.flush();
if (data[0] == 0xff)
int sum;
sum = (data[0] + data[1] + data[2]) & 0x00FF;
if (sum == data[3])
distance = (data[1] << 8) + data[2];
if (distance > 30)
Serial.print("distance=");
Serial.print(distance / 10);
Serial.println("cm");
} else
Serial.println("Below the lower limit");
{ float temperature = getTemp();
Serial.println(temperature);
int sensorValue = analogRead(A0);// read the input on analog pin 0:
float voltage = sensorValue * (5.0 / 1024.0); // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
Serial.println(voltage); // print out the value you read:
startWait += waitMillis; // new start for next interval
float getTemp(){
//returns the temperature from one DS18S20 in DEG Celsius
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
//no more sensors on chain, reset search
ds.reset_search();
return -1000;
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return -1000;
if ( addr[0] != 0x10 && addr[0] != 0x28) {
Serial.print("Device is not recognized");
return -1000;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
byte present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for (int i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
ds.reset_search();
byte MSB = data[1];
byte LSB = data[0];
float tempRead = ((MSB << 8) | LSB); //using two's compliment
float TemperatureSum = tempRead / 16;
//startWait += waitMillis; // new start for next interval
return TemperatureSum;
