i need schematic diagram and values of components
WINPINPH1
Joined Sep 27, 2010
24
i would like to create a project utilizing all 10 output of 4017b and using relay to switch on/off a 220vac. The load is only a 1 cellphone charger which i think has a very minimal current to use.
I want to know the specific values of different components specially the relay.
I hope someone could help me.
SgtWookie
Joined Jul 17, 2007
22,230
If you would like to create a project, then why do you want someone else to do it for you?
There is so much left out of your initial project statement that it is nearly comical.
4017's don't source much current, so they would be unable to activate a relay's coil by themselves; they would need to drive MOSFET gates or BJT bases instead.
However, I really don't have a clue what you're trying to do.
marshallf3
Joined Jul 26, 2010
2,358
Last I recall a 4017 was some sort of decade counter?
Yea, this ought to be a good one to hear more about.
Nevermind, some sort of pattern is falling into place by all these new member's posts.
Wanting to reduce a generator's speed
wanting to divide line voltage frequency down
another divider circuit to feed a power supply
and a few others along similar lines.
Perhaps they've been told the very, very first about PWM and are trying to come up with ways to save power without affecting output.
WINPINPH1
Joined Sep 27, 2010
24
from the circuit i attached i want is to control the 220vac circuit.
when relay is close the cellphone charger that is plug will work. if the relay i open the cellphone charger will not work.
i have 10 different chargers for 10 output of 4017b.
SgtWookie
Joined Jul 17, 2007
22,230
I fail to see why you would want to do such a thing.
Plug all of the chargers into a power strip, and be done with it.
If you only have one cell charger and many identical phones, I could see why you would want to multiplex the charger. However, what you're wanting to do just makes no sense.
WINPINPH1
Joined Sep 27, 2010
24
i have many different chargers for different cellphones.
the ac current flow is also controlled by a timer. I want to make a cellphone charging station. Customer will have to drop a coin and the charger will work for a certain period of time controlled by the timer.
the 4017 will controll the type of charger to use and also to minimize the electricity bill as well. If the all of the charger are working at once then i will accumulate a higher electricity bill.
bertus
Joined Apr 5, 2008
22,988
When the input switches are open you have open inputs on the counter.
Use some 1 - 10K resistors from the input to ground, this will ensure a low input when the switches are open.
bertus
Joined Apr 5, 2008
22,988
The resistors should be at the R , EN and clock (the triangle) inputs of the counter.
A debounce on the clock would also help.
marshallf3
Joined Jul 26, 2010
2,358
So in effect you're selling electricity say, in a shopping mall.
You'll have a variety of chargers, hopefully one of which will fit a person's phone.
Somehow it's going to have to have a way to know which charger to energize when a coin is dropped.
Seems to me to get back your investment you'll have to do a lot of business, coin recognition devices are far from inexpensive.
Still don't know why the logic IC. One coin mechanism on each charger or do they select which charger first then drop a coin and only that one activates, then another person comes by, selects a different charger, drops a coin and that charger will also come on?
You could almost pay a person's salary to manually operate something like this and how are you going to know the time? Some phones charge in 30 minutes, others take hours. I suppose the customer is just going to wait while their phone charges?
WINPINPH1
Joined Sep 27, 2010
24
as of the moment i have no problem in setting up the time and coin operated machine.
the schematic has an led to determine which output is energized. basically drop coin, select the type of charger and then charge the phone.
after i tried simulation. using 220vac and filament rated 240v at first output i got a busted filament second output i got a busted filament and a busted relay...i did not try the other output maybe the same.
what seems to be the problem? is it the relay?
SgtWookie
Joined Jul 17, 2007
22,230
1) Output 0 should be left unconnected, as you don't want to be powering a charger when the 4017 is reset. Use only outputs 1 through 9 instead.
2) R21 through R23 should be 10k resistors instead of 1k resistors.
3) Add 10nF (0.01uF) to 100nF (0.1uF) capacitors from the 4017 side of the switches to ground, and add a 1k resistor between the left side of the switches and 5v. This will help with switch de-bouncing.
4) 1k is too low of a resistance for the 4017 output to drive. Consider replacing the base resistors and the 2N3904's with a ULN2804; which is an 8-channel Darlington driver. You could use a single Darlington transistor with a 7.5k base resistor and a reverse EMF protection diode for the last remaining channel.
I have no idea why your simulation is failing, as you have not posted a complete schematic.
WINPINPH1
Joined Sep 27, 2010
24
1. so you mean sir i can utilize only 9 output?
2. i can do it.
3-4. This one i need help can you please edit the schematic diagram for me?
The diagram for 4017 is complete as my main concern is to drive a switch using relay.
