I need help..asm
SAADABDOO2
Joined Jan 19, 2009
1
I want asm program about counter up/down using PIC16F84,
start:
IF count =10; yes{ set RB6 ;
change: IF button1 Pressed;yes{decrement count;​
goto start ;}}
No {go to start;}​
No {clear RB6 ;
IF button2 pressed ;yes{increment count;​
delay: set RB7;​
IF button3 pressed;yes{clear RB7;​
go to start;}​
No{go to delay;}​
No {go to change;}
end;
circuit....
(decrement button1 connect to (RB2) = push-button used to decrement count)
( increment button2 connect to (RB1) = push-button used to increment counter, & set RB7=1)
(ENTRY button3 connect to (RB3) = push-button used to clear RB7 =0)
( RB1,2,3 of portB are input , others output)
The flow diagram of the program in file....
RiJoRI
Joined Aug 15, 2007
536
Saad --
The [ code ] & [ /code ] commands will allow you to properly format code. Using ----------'s is almost guaranteed to reduce the number of replies.
Also, this seems to be partial pseudo-code. What have you done so far? Let us see it with the [code ] & [/code ] commands.
--Rich
