\(I_b={{V_s}\over{R_c\; \beta_{min}\)hi all
i need find the value of the Base resistor (Transistor Switching Circuit)
thank you AudioguruNo.
Beta is not used for switching transistors. It is used when a transistor always has plenty of collector to emitter voltage when used as a linear amplifier.
The datasheet for nearly every transistor shows the max saturation voltage when the base current is 1/10th the collector current.
This is definitely a good point by both you and SgtWookie. My answer could be considered the minimum Ib that can be used safely. The application really dictates whether it is critical to operate deep into saturation.The datasheet for nearly every transistor shows the max saturation voltage when the base current is 1/10th the collector current.
Datasheets have curves of typical transistors that saturate deeply and written spec's for the max saturation voltage for a transistor that is not as good as a typical transistor and its saturation voltage is not very "deep".This is definitely a good point by both you and SgtWookie. My answer could be considered the minimum Ib that can be used safely. The application really dictates whether it is critical to operate deep into saturation.
I agree with you. Please provide the overall goal of your electrical circuit and what type of transistor are you reviewing to incorporate into the electrical circuit.This is definitely a good point by both you and SgtWookie. My answer could be considered the minimum Ib that can be used safely. The application really dictates whether it is critical to operate deep into saturation.
Yes, of course I don't want to test every transistor. Basically, I agree with your comments which is why I said you had brought up a good point. If you notice, my post was very careful about using worst case numbers for everything in the calculation, including the minimum possible beta with manufacturing variations, temperature, current etc. In situations where low saturation voltage is not critical, I often use values of 20 or 30 rather than 10 (if the data supports this decision), but I agree that the saturation voltage will be higher if this is done. However, his simple example does not have any specifications about how saturated the transistor needs to be.Don't you want every circuit you make to work properly without testing the saturation voltage of every transistor?
Definitely a good point!This discussion could go on for weeks.
Sure, you could use a number of approaches.
My point is pretty basic; this boards' membership has a rather high concentration of "electronic newbies", who are struggling valiantly to do something like getting their first LED to flash on and off.
In order to help such budding enthusiasts have very high probability of success with a minimum of confusion, it is a good idea to put forth the simple standard "rule of thumb" of Ib=Ic/10 when using a transistor as a saturated switch. If they follow that rule, they have a very high probability of good results.
