I need a VERY NICE project idea for an old coil meter
q12x
Joined Sep 25, 2015
2,245
I have several 50mA meters. They are a resistor inside. I remove the shunt resistor, and the meters are now 100uA meters.
I repaired mine and I know it's inside very well by now. It has no internal resistor like yours have. I had to add that 200R for the needle to stay in the middle of the dial, but thats it.
- another minor tweak:
before it had a 1k in series with that pot. Removing it, is a tiny bit better and also simplify the cct.
q12x
Joined Sep 25, 2015
2,245
back to the box then - eh, pitty we couldnt find a nice project for it.
not all wars can be win, right?
q12x
Joined Sep 25, 2015
2,245
update:
note: I made 3 movies before that were short, so I decided to make a single movie with all 3 in 1. I also added a 4th movie in continuation.
I made it simple to skip everything you may have seen already with a very easy link list in the movie description there on YT.
Click on those links and you will be teleported to the right part/movie.
Thank you.
Jean82
Joined Jun 12, 2023
28
With a little modification, You can use this as a weight scale, sensitive in the microgram range.
:)The unknown weight can be put on the end of the needle. Gravity changes the position of the needle, and You can compensate against it by driving a current through the coil. The original position can be sensed somehow. Then, the current is proportional to the unknown weight - can be digitized, sent through the Internet or something.
