I have to design a 4-bit multi-mode counter circuit
kstar1996
Joined Jun 7, 2016
7
using D flip flops, multiplexers, and combinational logic. The clock frequency of the counter circuit is 25 Mhz and here is the block diagram.
dl324
Joined Mar 30, 2015
18,506
Yes it is. I just need help for starting it off though... because it's due tommorow.
You didn't allow enough time. AAC Members don't do the homework for you. Most problems take days to work through because we will only give you hints.
Is your counter supposed to be asynchronous or synchronous?
kstar1996
Joined Jun 7, 2016
7
Actually it doesn't say anything about that in the problem. All it told me to do was what I wrote above.
dl324
Joined Mar 30, 2015
18,506
What type of counters were you studying before this project was assigned?
Is it supposed to be binary or decade? What are the "multi-modes"?
dl324
Joined Mar 30, 2015
18,506
You have 4 inputs; is the counter supposed to have a load function? Is clear supposed to be synchronous or asynchronous?
dl324
Joined Mar 30, 2015
18,506
You have to do a synchronous counter design. Have you been studying excitation tables, transition tables, and Kmaps? Is clear supposed to be implemented? It's shown in the first picture, but not mentioned in the last post.
kstar1996
Joined Jun 7, 2016
7
I'm sorry, but English isn't my first language so I can't understand by what you mean when you say "Is clear supposed to be implemented?" We did study Karnaugh Maps, transition tables, and I don't remember about excitation tables, but we probably did. I will just give the entire problem. I have to draw it using the SimUAid tool.
dl324
Joined Mar 30, 2015
18,506
The first thing you need to do is create an excitation table that will have 6 inputs. Have you studied how to simplify 6 variable Kmaps? Were you taught some short cuts to keep the Kmaps more manageable?
33,326
Multimodes are just the same thing as up-down counters and it's supposed to be binary.
Well this is all it gave in the problem other than what I said above.
This last one is what you should have started with. How can anyone help you when you tease out important parts of the problem in dribbles and drabs. Doesn't it seem reasonable that, for anyone to offer any assistance at all, that they would need to know what, exactly, each of the four most modes is. Also, does Gray Code and Right Shift really sound "just the same thing as up-down counters"? And notice that you don't need to implement a down counter at all.
There are a number of ways of tackling the problem. From a state machine standpoint, you have two inputs (assuming that we let the clear be asynchronous -- which may or may not be a valid assumption for your assignment) and four state variables. That's a six-variable K-map, which is about the largest that students are generally ever expected to deal with. But the fact that you are told to use multiplexers is a big hint as to another way of doing it: Design the logic for each of the four states separately and then use the multiplexers and the mode inputs to select which set of next state signals to use.
Now the ball is in your court -- we need to see a meaningful attempt on your part to work your problem. That gives us the necessary starting point from which to start. We will point out where you are going wrong and help guide you back to a path that heads you in the right direction. But YOU have to do the work. Leaving it to the night before it's due was a bad idea -- but if nothing else, perhaps it will teach you to not leave your homework until the night before it's due.
