I don't have an oscilloscope
Arjune
Joined Jan 6, 2018
354
This is my 1hz pulser. Will lo state reach close to zero (I want that) volts at output? I don't have an oscilloscope to see the waveform. I know the hi state is 5.3v. I am able to clock a cmos modulus 60 counter okay with it. Can it clock TTL.
danadak
Joined Mar 10, 2018
4,057
If you do not have a scope here is a low speed freebee -
You can start with a PC sound card based scope for free. Will give you basically
audio range scope, spectrum analyzer, and function generator all using your
PC sound card. It may not be fast enough to handle the character LCD interface
however.
https://www.zeitnitz.eu/scope_en
http://www.zelscope.com/
http://www.ledametrix.com/oscope/
http://www.virtins.com/downloads.shtml
But first build a simple circuit to protect sound card inputs so you do not
ruin from transients, overvoltage. Google "protect sound card input".
For example http://makezine.com/projects/sound-card-oscilloscope/
A real inexpensive Logic Analyzer/pc combo can be had with this -
https://www.ebay.com/itm/USB-Logic-...h=item33f2ef28ec:g:NNoAAOSwjXVaoiyH:rk:4:pf:0
There are many vendors of this on ebay.
You download and install Saleae software to run it. https://www.saleae.com/downloads/
Sound card impedance bridge -
http://www.marucchi.it/ZRLC_web/ZRLC/Steber_An_LMS_Impedance_Bridge.pdf
http://www.sillanumsoft.org/ZRLC.htm
Regards, Dana.
spinnaker
Joined Oct 29, 2009
7,830
however.
Regards, Dana.
Of course you risk frying your sound card so bear that in mind before taking this advice.
The better advice is to buy a cheap USB scope. There are many on eBay and other places.
Here is a nice standalone one for only $27 US
https://www.ebay.com/itm/DSO150-2-4...m=192807997631&_trksid=p2047675.c100005.m1851
Here is a name brand one for a bit more but requires a PC.
https://www.ebay.com/itm/New-Useful...530143?hash=item3fa7c33e1f:g:qDwAAOSw1opba-9f
Another cheap one:
https://www.ebay.com/itm/77CE-Assem...f4:m:m8nNY-e0SFLE8J9flyEWTOw&var=553166751305
dl324
Joined Mar 30, 2015
18,427
I designed digital circuits for many years with a voltmeter and a logic probe. For clocks, you just need a frequency divider to make it slow enough to see with a visual indicator.
Why are you using a BJT and a MOSFET? One or the other should be sufficient.
Is there a current limiter in CM1?
EDIT: To answer your question, it can drive TTL, but you should decrease the voltage to 5V.
spinnaker
Joined Oct 29, 2009
7,830
And does the cheap logic analyzer actually work with the saleae software? Download page says it is demo software or at least has demo mode.
Arjune
Joined Jan 6, 2018
354
I am afraid to use the sound card, I don't want to lose my HP laptop. The USB scope on ebay for $27 sounds promising. Is there an installation disk for software? If so, what kind?
Arjune
Joined Jan 6, 2018
354
I don't know of a current limiter in CM1, the clock is powered with a 1.5v cell. I am using the 2n7000 because a BJT output was 4.3v only (I need 5v) as an emitter follower. My logic probe indicates that hi and lo levels are fine with the schematic circuit I provided.
spinnaker
Joined Oct 29, 2009
7,830
I think that $27 is a stand alone. But I would consider spending a bit more and getting the Hantek. It would make it a lot easier for you to share wave forms on the forum.
dl324
Joined Mar 30, 2015
18,427
When the transistor is off, the output should be supply voltage. It's the load that's causing the voltage to drop.
Replace D3 and D4 with 1k resistors, change R4 to 1k. and take the output from the collector of the BJT. High level output voltage should be 5.25V.
danadak
Joined Mar 10, 2018
4,057
There are many decision to make buying a scope. Some points -
1) Battery operated scope intrinsically isolated. See following for why this
is important in some situations.
https://www.newark.com/pdfs/techarticles/tektronix/FFM.pdf
https://www.tek.com/document/application-note/three-facets-floating-measurement-solutions
https://www.picotech.com/library/oscilloscopes/differential-and-floating-voltage-measurements
2) Triggering capabilities go from basic to extensive. On you tube you can see videos
on advanced scopes, look at one just to give you an idea of what triggering does for
you.
3) Infinite persistence on a scope very useful. Look at noise, like on supply rails.
4) Anything that plugs into a PC or Laptop can take it down. Its a fact of life. A scope
plugged into USB and trying to do line measurements tricky, read the ap notes above.
5) Some basic math capability, like subtract Chan B from Chan A.
6) Two channels and ability to do basic differential measurement quite useful.
And this is a way of making safe measurements over single ended measurements.
7) 10X probes are your friend.
8) If you can get it FFT on scope very useful. 6022BE seems to have it.
Just a few, there are threads on this forum discussing low end and other scopes. Take
time to investigate. You are in no hurray to buy the wrong solution.
Here some reviews of 6022BE - https://www.eevblog.com/forum/testgear/hantek-6022be-will-it-work-for-me/
Most scopes vendors allow you to download software to look at it, try before you
buy (to some extent). Manuals of course rich in info.
Regards,. Dana.
Arjune
Joined Jan 6, 2018
354
It's working okay with the output from the drain of the FET, I'll leave it the way it is. I just have to put the circuit board in a box now. My 4"x6"x3" abs plastic box cost me $10 on eBay. Is there a cheaper source, especially for bigger boxes.
dl324
Joined Mar 30, 2015
18,427
Looks good and free shipping. It looks like it's not transparent but it says it's clear and wiring would show through. We need to hide wires so people wouldn't think it's dangerous.
Free shipping may not last because the current Administration is in a trade war with China.
Lead times are listed as 30 days or more. I've found that they're conservative in their ETA's. That particular box is only on sale for a few more hours. After that, it's closer to the $10 you paid on eBay. Chinese sellers also list on eBay.
Arjune
Joined Jan 6, 2018
354
I don't think the Hantek 6022BE is for windows 8 operating system. I am running Windows 8.1 on my HP laptop. Am I wrong?
DickCappels
Joined Aug 21, 2008
10,661
To the question in the OP, yes the output should get very close to ground. I should able to clock TTL but the 1k + LED load may give you trouble getting an output voltage that is a reliable high state for CMOS or TTL. I suggest buffering the LED.
Arjune
Joined Jan 6, 2018
354
Thank you, I feel better now.
