I am learning about VCOs. How can I add PWM to my current design.
Emmanuel Galvan
Joined Aug 9, 2017
Hi all!
This is my first post here and I am looking for directions and will appreciate any pointers and or tips derived from your experience.
I'm currently working on a VCO for an audio application (I am a sound engineer and just finished a course on radio and amplification) however I do have some questions that I'd like some help with.
I designed a VCO using what it seems to be a typical op-amp configuration for this application (image attached).
With some tweaks and experimenting I've got a nice sounding square wave output. As I have experience with other oscillators, I kind of like how they sound with PWM. After perusing some schematics and looking at other VCOs I have concluded that, in order to add a PWM function to my oscillator, what I'd have to do is:
1) Breadboard a similar VCO to the one I've built.
2) Combine their outputs with an op amp in a comparator configuration.
Am I correct?
Am I complicating things?
This is a learning exercise for me and I am trying to challenge my current abilities so I can improve, however I thought it might be of benefit to seek some guidance here.
Thanks in advance!
Emmanuel.
Emmanuel Galvan
Joined Aug 9, 2017
You're on the right track.
But I don't understand the purpose of the PWM.
What signal will you use to modulate the PWM?
Well, as I understand (or trying to) I'll be using one oscillator to modulate the others's pulse width and thus changing the sound of the VCO. I am trying to achieve something similar to this:
38,952
So you just connect one input of a comparator (such as the LM339/393) to the VCO triangle output, with the other input being the PWM modulator signal.
When mod input voltage equals 1/2 the triangle voltage, the PWM duty-cycle will be 50%.
