HW Help: Boolean Simplification
rtran2015
Joined Oct 3, 2015
13
=ABCD' + AB' + AC' + AD' + A'B'C'D'
=AD'(BC + 1) + AB' + AC' + A'B'C'D'; T8 <--- ABCD' + AD'
=AB' + AC' + AD'(1) + A'B'C'D'; T2' Null Element
=AB' + AC' + AD' + A'B'C'D'; T1 Identity
=AC' + AD' + B'(A + A'C'D'); T8
=AC' + AD' + B'(A + C'D'); T10
=AB' + AC' + AD' + B'C'D'; T8 <--- Everything at minterm?
I can un-distribute A, though these terms seem to be the most simplistic
Y = AB' + AC' + AD' + B'C'D'
if AB' is true, does it matter if the rest is true or false because its in an OR gate?
The truth table for this equation:
A B C D= Y
0 0 0 0 = 1
0 0 0 1 = 0
0 0 1 0 = 0
0 0 1 1 = 0
0 1 0 0 = 0
0 1 0 1 = 0
0 1 1 0 = 0
0 1 1 1 = 0
1 0 0 0 = 1
1 0 0 1 = 1
1 0 1 0 = 1
1 0 1 1 = 1
1 1 0 0 = 1
1 1 0 1 = 1
1 1 1 0 = 1
1 1 1 1 = 0
We can remove all the ones that equal zero
A B C D= Y
0 0 0 0 = 1
1 0 0 0 = 1
1 0 0 1 = 1
1 0 1 0 = 1
1 0 1 1 = 1
1 1 0 0 = 1
1 1 0 1 = 1
1 1 1 0 = 1
32,825
No. A minterm is True for exactly one combination of inputs, which means that it is the AND of all four inputs (some of which might be complemented).
What you have is simply a Sum of Products, or SOP, expression. Which is what you are looking for.
No, it doesn't matter. Any time any term is True, the status of all of the other terms is irrelevant.
A B C D= Y
0 0 0 0 = 1
0 0 0 1 = 0
0 0 1 0 = 0
0 0 1 1 = 0
0 1 0 0 = 0
0 1 0 1 = 0
0 1 1 0 = 0
0 1 1 1 = 0
1 0 0 0 = 1
1 0 0 1 = 1
1 0 1 0 = 1
1 0 1 1 = 1
1 1 0 0 = 1
1 1 0 1 = 1
1 1 1 0 = 1
1 1 1 1 = 0
A B C D= Y
0 0 0 0 = 1
1 0 0 0 = 1
1 0 0 1 = 1
1 0 1 0 = 1
1 0 1 1 = 1
1 1 0 0 = 1
1 1 0 1 = 1
1 1 1 0 = 1
And what does this accomplish? If you are going to show a truth table, then show a truth table.
rtran2015
Joined Oct 3, 2015
13
Got it
Thank you very much for your help, patience, and examples
I should be able to get through most of this homework assignment
