Hey all, new to the forum and hoping for some help.
I build custom motorcycles and the latest project is heavily based on a smart ecu unit controlled by a Bluetooth device.
Apart from that, the bike has obvious warning signs (indicators,neutral,oil level)
The issue is, the bike uses a oil level switch. When the oil level is correct it supplies a earth to the warning light through a controller.
Problem with that is that obviously this leaves the light on constantly when riding.
Does anybody know of a small relay that when receiving a earth would not give out a earth supply and will give a earth when not receiving a signal from the switch?
Will need to be pretty small as there’s not a lot of room.
I’m aware conventional automotive relays take a signal and supply an output but no good for me.
If this is possible, I’m in London and need one ASAP so if anyone knows is I can get something like this in Maplins etc?
Thanks in advance
J
Thanks in advance
J
