Hi there,
I am trying to create a circuit to measure humidity in the air.
When I try to interpret the values obtained, they do not correspond to the table of values that the manufacturer of the HR202L provides.
Could someone explain to me the possible errors in my circuit or my calculations?
I am using this HR202L sensor that varies its resistance based on the humidity in the air.
I want to increase the sensitivity of the measurement, so I decide to use an opamp as differential amplifier configuration.
The reference voltage is the midpoint between the voltage when humidity is maximum and the voltage when humidity is minimum.
Thank you all and please let me know if something is very incorrect or poorly explained.
