That gun is a wall-hanger, you couldn't pay me to load a 7.62x54R and pull the trigger.. I already have a Soviet Tula arsenal SKS in my collection.Nice! Have you considered upgrading from M44 to SKS-45?
(I will not even mention SVT-40).
You just need to do it Soviet style, get cotton stuffed short winter jacket: https://www.ebay.com/itm/VINTAGE-RU...m3b0bcc6cda:g:yz8AAOSw6-Nb1s3T&frcectupt=trueThat gun is a wall-hanger, you couldn't pay me to load a 7.62x54R and pull the trigger.. I already have a Soviet Tula arsenal SKS in my collection.
No thanks. For me that would be like putting on a KKK robe. I like collecting weapons of former adversaries, not emulating them.You just need to do it Soviet style, get cotton stuffed short winter jacket: https://www.ebay.com/itm/VINTAGE-RU...m3b0bcc6cda:g:yz8AAOSw6-Nb1s3T&frcectupt=true
Then put the recoil pad on the carbine.
Then you shoot it.
That should work nicely on a dl380. Doesn't need a Supplementary Power Connector either at 75W (max power for a pci-e slot card only).nsa, saw this today and thought of you: https://www.newegg.com/Product/Product.aspx?Item=N82E16814500411&Description=zotac gtx 1050&cm_re=zotac_gtx_1050-_-14-500-411-_-Product
it kinda looks low profile, but I think it takes two slots. I don't think it will fit dl360, but it might work for dl380.
Wait...it can't draw straight lines?Sweet! Linux 64-bit Eagle Cad auto-route on the 12 processor machine.
I haven't used an autorouter in a long, long time. But the ones I used in the past tended to minimize the number of jogs during the routing process. Lots of in-process rip and replace, but even the intermediate results were far cleaner than what your package is generating.
That's the first approximation (looks like a drunkard's walk probability path) of interconnects. optimizing and making straight lines takes a lot longer.
The intermediate results are meaningless if the final result is superior. I've got complex RF acceleration systems that can use two methods to fine tune beam power.I haven't used an autorouter in a long, long time. But the ones I used in the past tended to minimize the number of jogs during the routing process. Lots of in-process rip and replace, but even the intermediate results were far cleaner than what your package is generating.
10GBASE-T 10G copper CAT 6A STPWhat are you upgrading the server backbone to? Fiber?
Disk based tape emulation backup to XFS file system on mirrored raid 8TB drives.11-Mar 16:36 sma2-sd JobId 12177: Elapsed time=00:09:12, Transfer rate=68.16 M Bytes/second
11-Mar 16:36 sma2-sd JobId 12177: Sending spooled attrs to the Director. Despooling 46,687 bytes ...
11-Mar 16:36 sma2-dir JobId 12177: Bacula sma2-dir 9.6.7 (10Dec20):
Build OS: x86_64-pc-linux-gnu debian bookworm/sid
JobId: 12177
Job: hp8.2023-03-11_16.27.25_14
Backup Level: Incremental, since=2023-03-10 23:05:03
Client: "hp8-fd" 9.6.7 (10Dec20) x86_64-pc-linux-gnu,debian,bookworm/sid
FileSet: "Full Set" 2021-10-08 16:24:26
Pool: "File" (From Job resource)
Catalog: "MyCatalog" (From Client resource)
Storage: "File2" (From Job resource)
Scheduled time: 11-Mar-2023 16:27:21
Start time: 11-Mar-2023 16:27:27
End time: 11-Mar-2023 16:36:40
Elapsed time: 9 mins 13 secs
Priority: 10
FD Files Written: 217
SD Files Written: 217
FD Bytes Written: 37,628,776,398 (37.62 GB)
SD Bytes Written: 37,628,801,103 (37.62 GB)
Rate: 68044.8 KB/s
Software Compression: None
Comm Line Compression: 32.5% 1.5:1
Snapshot/VSS: no
Encryption: no
Accurate: no
Volume name(s): Vol-1172
Volume Session Id: 9
Volume Session Time: 1678481614
Last Volume Bytes: 39,303,478,082 (39.30 GB)
Non-fatal FD errors: 1
SD Errors: 0
FD termination status: OK
SD termination status: OK
Termination: Backup OK -- with warnings
Bluetooth cache (Linux) | Software & IDEs | 3 |
| Similar threads |
