Does it tell your coworkers when they need more deodorant?Maybe you can guess what the app does.
The alternative is 10,000 posts about how to connect an LED to mains.I haven't followed this thread much because 980 posts about the weather seemed ... excessive.
To ventilate holds loaded with cargo that could be damaged by moisture you always compare the inside DP with the air DP. As long as air has a lower DP, you ventilate. Exactly the same reasoning they used in the old times, to ventilate or not the "santabarbaras", (powder-magazines) in old warships.No, the lower the dew point, the dryer the air and the greater the imbalance between liquid water (Sweat) and vapor.
Fascinating. That's getting very close to what my app does.To ventilate holds loaded with cargo that could be damaged by moisture you always compare the inside DP with the air DP. As long as air has a lower DP, you ventilate. Exactly the same reasoning they used in the old times, to ventilate or not the "santabarbaras", (powder-magazines) in old warships.
Wet and dry bulbs readings entered regularly in the log book, were compulsory in the old times for certain vessels. They formed part of the information sent every 12 hours to shore stations collecting meteorological information.
Any weather app can give you DP, relative humidity and wet bulb. All give an idea of the same thing, the wetness of the air. Energy content (enthalpy) is nearly proportional to wet bulb. Humidity – not relative, but the amount of water per unit of dry air – is proportional to dew point.Pretty neat. Do they have an app. that can monitor and display DP?
Not sure what they use nowadays in very specific vessels. Something like your app surely would be appreciated.Fascinating. That's getting very close to what my app does.
That's one of the first things you learn in college...no matter which subject you choose, there are people that are decades ahead of you.Wow, now I realize that my question wasn't that stupid after all. Things sure are a bit more complicated than they seem when you take a closer look at them.
That chart took up a week of class time just to get familiar with it. Obviously more time to get good at it.Fascinating chart... will study it, and probably get back to you with a million more questions. Thanks!
How often do you use it?That chart took up a week of class time just to get familiar with it. Obviously more time to get good at it.
Not much. I used it for wayneh in his humidifier quest. I use it for original A/C designs or strange stuff like a printing shop where humidity control is as important as temperature control. It's pretty useless for day to day A/C repairs and replacements unless you get into a question like tcmtech, "Why doesn't a new A/C work as well as a 30 year old A/C?" That's when I get down to the nitty gritty on measurements.How often do you use it?
Well... why doesn't it?"Why doesn't a new A/C work as well as a 30 year old A/C?"
Look at wayneh's humidifier Thread.Well... why doesn't it?![]()
Are you going to use it as a dehumidifier?My new A/C will be here tomorrow!
Close. It uses psychrometric data about inside air and compares it to outside air (with data from checking the local weather), and produces a decision on whether to prefer outside air for ventilation. Should I open the windows, or not?Wayneh, I'm guessing that your app simplifies the interpretation of DP relative to other parameters to help you decide a course of action on whatever it is that the user is managing.
Yes! I'll set it on a stand in the basement, and find a way to route the water out of the machine and into the floor drain.Are you going to use it as a dehumidifier?
Yup, I can remember struggling with it a lot the first time through, and any time I haven't used one for a while. Don't get me started on Mollier diagrams!That chart took up a week of class time just to get familiar with it. Obviously more time to get good at it.
| Thread starter | Similar threads | Forum | Replies | Date |
Looking for Advice on Adding Wi-Fi and Home Assistant Support to Weather Monitoring System | Microcontrollers | 3 | |
Weatherproofing a pushbutton | General Electronics Chat | 41 | |
| S | [PCB Review Request] ESP32 and Nano Weather Station board | PCB Layout , EDA & Simulations | 2 |
