How would a light bulb's Lumens increase with a decrease in Watts?
kubeek
Joined Sep 20, 2005
5,796
Studiot: Hm. I think I see the direction you're going. But let me ask with a simplistic example: Let's say we have a basic battery based circuit with a small 10 watt bulb and 2 batteries: one that is able to produce (or be drawn from) 30W and another at 20W. First you use the 30W battery in the circuit and you get a X lumens. Then, using the same 10W bulb, you switch to the 20W battery but this time you get an increase to Y lumens (I changed my example a bit).
If the two batteries have the same voltage, than the power the bulb draws will be the same - 10W. It doesnt matter how many watts your power source is capable of, only the voltage matters.
studiot
Joined Nov 9, 2007
4,998
Unfortunately you didn't see the direction.
I asked a simple question, which was:
Take a bulb and connect it to a power source so that it draws X watts.
How do you intend to cause that bulb to draw Y watts?
For your information it is the load (bulb) that determines the power not the supply.
alfacliff
Joined Dec 13, 2013
2,458
you can not "give ' something less watts. you can lower the voltage, whitch will reduce the current, giving less watts, but it is up to the load to "take " the watts. like trying to force feed something, loads dont like it. and less watts means less lumens output because of less power supplied.
ptownbro
Joined Sep 28, 2013
17
Actually, I did see the direction you were going in. Meaning, saying that the load determines the power, not the supply is what I thought you were going to say. Thanks!
WBahn I think provided a subtenant and relevant answer and seemed to truly get the spirit of what I was asking and restated it better.
