How wide is the river?
Hymie
Joined Mar 30, 2018
1,347
I offer this maths question in that it is unlikely you encountered such a problem during your school years – and so is not solvable by rote.
When I first encountered the problem, I was not convinced that there is sufficient information to give a definitive answer.
I have seen a number of worked solutions to the problem – but the simplest solution involves very little maths. In giving an answer, please show your working.
Q: How wide is the river?
Two ferry-boats start moving at exactly the same time from opposite banks of a river, heading to their opposing start points. One boat is travelling faster than the other, such that they cross at 720 metres from the nearest shore. After arriving at their destination, each boat remains for 10 minutes before starting on its return trip. The boats again cross, but this time at 400 metres from the other shore. What is the exact width of the river?
(For the purposes of this question, the boat lengths should be ignored and be considered represented by a single point; and that when in motion, each boat is moving at a constant speed)
BR-549
Joined Sep 22, 2013
4,928
Is the "nearest" shore....the shore that of the reference starting point/boat? Is where the boat started....the nearest shore. OR is the "nearest" shore from where the boats meet?
Can you restate problem with boat A and B and west bank, east bank?
The "other" side.....depends on where "nearest" side is.
33,287
When they meet they are a distance X from one shore (Shore #1) and a distance Y from the other shore (Shore #2).
If X and smaller than Y, then Shore #1 is nearer than Shore #2 making Shore #1 the nearer shore and Shore #2 the other shore.
33,287
Do both boats keep the same velocity? and start times?
Well, let's see what the problem states:
33,287
Wouldn't the same boat always intersect at same length of travel?
Huh???
They intersect twice, once going out and once coming back. Clearly the total length that each boat traveled is going to be longer when they intersect the second time that it was when they intersected the first time.
Hymie
Joined Mar 30, 2018
1,347
If you consider that when the boats first cross, the nearest shore is designated A, then when they next cross at 400 metres from the other shore – this other shore must be shore B.
BR-549
Joined Sep 22, 2013
4,928
I can't figure out how boat a can leave west bank....intersect at 720 m.................Hit east bank...which is the OTHER side.......then only intersect 400 m from the OTHER side????????????? I could understand being 400 m from the near side..........but not the other side.
Is this length contraction?
near and other are bad words.
BR-549
Joined Sep 22, 2013
4,928
The width of the river depends on whether you are asking the man on the near shore....or the man on far shore.......or the man on the boat.
It's relativity.
BR-549
Joined Sep 22, 2013
4,928
I don't know about the rest of you....but my boat has a 720m per intersection rate.
And if after the first intersection back......I only have 400 m left.....it's evident.
Hymie
Joined Mar 30, 2018
1,347
It's relativity.
Imagine that you are on a boat in a river – and you are asked to swim to the nearest shore; for most people the meaning of the nearest shore would be pretty obvious.
Hymie
Joined Mar 30, 2018
1,347
If it is any consolation – I could not solve this without being given the answer, including an explanation.
