What is the voltage with the old cap?I removed the 47uF cap, as it did not shutdown the alarm at all.
I did not see much use in finding out what the voltage was, seeing it did not work , I replaced it with the old cap.
Might be still be viable If 20 Hz is accurate. I can take another look into this later today.I’m still on the LM2917.
Years ago I used to fix classic cars’ Smiths Instruments Rev counters using a LM2917 circuit, and a connection to the contact breaker, and they worked correctly at idle speed.Might be still be viable If 20 Hz is accurate. I can take another look into this later today.
All my tests are done in the galley sink with pressurized town water supply:What is the voltage with the old cap?
Hi SG,Please post your redraw for review
Many thanks. SG, I wonder if you can modify it to 3Hz . than I draw this one out also.Now that you have done all of that I revisited the LM2907 circuit modified for 5 hz operation and added the same latch as in the previous 555 design. Bench verified at 5 hz with the same results.
The problem with the previous LM2907 circuit was too much hysteresis that required the flow rate to increase well above the nominal flow rate in order for the circuit to shut off.
In this latest version I eliminated the hysteresis and rewired for the latch circuit.
So is it working out?Looks like the 2917 is working perfectly, but we have the frequency wrong!
HiNow that you have done all of that I revisited the LM2907 circuit modified for 5 hz operation and added the same latch as in the previous 555 design. Bench verified at 5 hz with the same results.
When the frequency is higher then the threshold the output transistor in the chip is ON thus effectively shorting the base of Q1 to the supply voltage. When the transistor shuts off Q1 is biased ON through R5.Hi
Shouldn't Q1 be an NPN without R4? else, how will the PNP ever turn on?
| A | Shed a light on this wires gatherer in 400/40 Watt rice cooker | Technical Repair | 1 | |
| B | Wire Strippers | General Electronics Chat | 23 | |
How to drive a 5 wires stepper motor without Arduino ? | Digital Design | 17 | |
| A | USA 240V three wire L1, L2 and a Ground | Power Electronics | 22 | |
wire wrap pins | Marketplace | 10 |
