You also left out R3 the 10K resistor between pins 5 and 7. This resistor is important , it provides hysteresis so the output will switch cleanly between ON and OFF.I forgot the C1 from input, its back again
Did anyone mention that 2N2222 has a maximum Ic of 800 mA? Depending on the relay coil that you have, it could easily exceed that. You may be better off just powering the buzzer directly through the 2N2222, or else use a larger transistor.You're right. Thank you sir. Added 10K between pins 5 & 7
Relay shown on schematic is only 31ma.Depending on the relay coil that you have
Hi Bow ...Gentlemen, sghioto and drc_567
Apologies for the long delay, but I finally have some results of both 555 and 2907 circuits.
The following is for both circuits , Testing is done in the kitchen using a 12V car battery
I used LED's as outputs as trials with piezo buzzers made me deaf.
Powering up the alarm (led) switches on
Running water(at 3 liters/min) through the 32 mm sensor , shows the led flashing.
Increasing the resistance from zero( I use 2M Ohm trimpots) to 2M, makes the led start flashing slower and slower, but it does not switch of.
Next try:
set R back to zero
Increasing the water flow to 12 l/min. led is flashing as before
While increasing R slowly, the led flashes slower and slower until it switches of at 1.76M , but i am still getting the occasional flash. So increase it to 2M and i still get the occasional flash.(about every 20 sec)
The frequency is 5.5 to 6Hz
Next :
Disconnect and reconnect power, it starts slowly flashing again, without changing the Resistance setting
There are no mistakes in the circuit boards.
Blowing air into the sensor, makes the led switch of instantly -->so the circuits do work, except not very well at low frequency + the problem that neither switches of cleanly.
The above is valid for both designs
The above is in short what I have been doing for the last few days. can anyone shed some light on the problem?
Maybe Messrs sghioto and drc_567 are still monitoring this subject?
These test at 5 or 6 hz are not relevant.so the circuits do work, except not very well at low frequency
Hi DRC.. So the idea is to insert a Schottky Diode in between the hall effect sensor output and the counter chip.
... kind of a try it out and see suggestion.
Schottky Diode
Hi S, thanks for the reply.Welcome Back! Still monitoring here.
The 2907 circuit was designed to activate the alarm when the flow rate is below 90hz as that was based from our initial estimations of 112 hz at 1500 rpm, see post #20 to 22.
It would be normal for the alarm to activate on initial power up until the engine rpm and flow rate are above 130hz.
The test should begin at a flow above 130 hz to simulate actual conditions.
And this is all speculation. We need to get some actual flow rates with the engine running at different rpm.
Did you get the engine running?
... not quite following your circuit description, but basically the Shottkey Diode anode goes to the input terminal #2, and the diode cathode, with the stripe goes to the input of the counter circuit. Any series capacitor in the input would be to block a DC voltage component, but it is not clear if that is required.Hi DRC.
If I correctly understand what you mean, the Schottky diode goes directly to pin2&6and I get rid of the 4n7 cap?
It is the same as the diagram in post 49 where I replaced r3 (100K)with a 2M trimpot... not quite following your circuit description, but basically the Shottkey Diode anode goes to the input terminal #2, and the diode cathode, with the stripe goes to the input of the counter circuit. Any series capacitor in the input would be to block a DC voltage component, but it is not clear if that is required.
If is not too much trouble, post an update drawing of the latest circuit that you have.
The values we need to work with are a lot lower than what i suggested in post 20-23, as they were based on a cruising speed 7knots and engine running at 1500/1600rpm. and the presumption that the SW pump runs at the same speed.Hi Bow,
Sure we can start again.
I don't think you need 5 hz though. 5 liters/min should produce a sensor output of appx 37hz at engine idle based on our assumptions.
Maybe set a trip point at 30Hz. But what happens if you are cruising at say 1500 rpm and the water flow drops in half will the output from sensor drop below 30hz. My point is how bad of an obstruction is required to set off the alarm.
Do you have any means of reading the frequency output from the sensor during idle?
Working on it.The flow alarm should go of when the sensor frequency drops below 5 Hz
Can we work on 5Hz and I put 1M trimpot or a 1M 25 turn Cermet trimpot instead of a single resistor?
You can try that but change C to 1ufCan we work on 5Hz and I put 1M trimpot or a 1M 25 turn Cermet trimpot instead of a single resistor?
| Thread starter | Similar threads | Forum | Replies | Date |
| A | Shed a light on this wires gatherer in 400/40 Watt rice cooker | Technical Repair | 1 | |
| B | Wire Strippers | General Electronics Chat | 23 | |
How to drive a 5 wires stepper motor without Arduino ? | Digital Design | 17 | |
| A | USA 240V three wire L1, L2 and a Ground | Power Electronics | 22 | |
wire wrap pins | Marketplace | 10 |
