How to wire AC cable to DC cable
2Pringles
Joined Apr 9, 2022
38
USB3 or earlier were only 5V. USB C will likely be 20V, so you might be able to get one that could provide more than 35W and add two step down voltage regulators.
So somthing like two of these.
One 20v DC to 12v DC.
Other 20v DC to 5v DC.?
ericgibbs
Joined Jan 29, 2010
21,572
hi 2P,
If you can get these two wall wart power plugs into a UK dual extension socket that's OK, if not get a UK 4 way extension block, that's what I do if the two Wall warts are too big to sit side by side, in dual extension.
E
dl324
Joined Mar 30, 2015
18,467
I don't know enough about USB-C to say. I suspect there may be some communicating between the device and the port to determine voltage and current requirements.
The USB-C ports on electrical outlets will likely be a stripped-down version of USB-C.
2Pringles
Joined Apr 9, 2022
38
You mean regulate it down to 5vdc?
Correct, to you it may seem I am repeating myself, sorry, but I just want to make sure due to the multitude in jargon/terms in this field
How about somthing like this? -
Or even smaller still -
Either would be a real space saver, although the comment section of the resistor converter idea has alot of users complaining about it burning after a while, so that method seems a bit hacky?
Guys, am I correct in saying, to achieve the most smallest/compact AC to DC conversion, for my two devices, would be to have one 12V AC to DC converter, and then spur off it for the 5V device? so that I am saving technically 50% on some components(would the bulkly bit be a transformer?)
dl324
Joined Mar 30, 2015
18,467
What was the circuit they proposed? I'm not a big fan of watching YouTube videos from so-called electronics experts. That video was only 3 minutes long, but it didn't tell me anything in the first few seconds, so I lost interest.
This one is just a zener diode. It's the second voltage regulator they taught me in school and the only purpose was to show how inefficient it was before we moved to something that could really be called a voltage regulator. It's okay for low power, but you need 5V at 1A and that's far too much for a zener regulator. That 1A has to go through the resistor and that's extremely inefficient.
Just get a 12V adapter that can provide enough current for both of your devices and add a 5V switching regulator. Using a linear regulator would also be inefficient because your load needs 5W, but the regulator would have to dissipate 7W, i.e. more power than the load.
