Bordodynov
- Joined May 20, 2015
- 3,435
If you are satisfied with this algorithm, then my scheme is for you.
Dear Bordodynov,If you are satisfied with this algorithm, then my scheme is for you.
Dear Bordodynov,I am surprised. On my scheme, only 4 components. What is in the dotted square with an internal transistor is your receiver. A capacitor and a field effect transistor are added. A diode is also required. This diode is required when using an electric motor. My inductance is an imitation of an electric motor. The motor always has an inductive characteristic. Because of this property, an additional diode is needed. A simpler circuit that performs the necessary function cannot be.
Dear Bernard,Press a remote, motor runs. Tried 2 small motors , one with propeller. max 70 mA. Replaced motor with 7.5 ohm R, output 4.5 v, Vcc 5V. Need higher rated PNP than MPS2907 for 800mA start current.
Sensor used-TFM5368, output rectified with 1N4148, filter 4.7 uF, discharge -100k feeding 2N3906 emitter follower which goes to base via 27 ohm R of MPS2907. Motor collector & ground. Out of time.
Dear Bordodynov,Field effect transistor and diode may be different.But there is one moment.The remote sends a burst of pulses.If you apply a bipolar transistor, the LED will blink, but the fan motor will not work
Dear Bordodynov,Kelvin. I am disappointed. You do not understand me.
Bernard.
Look at my diagram. The rectifier is an internal transistor loaded on a 30kΩ resistor. For detection (rectification) it is enough to add a capacitor. I do not need a rectifier in the form of a diode .. In my mind, the transistor can produce 2mA.
Virtually none of that has anything to do with the receiver in question. It demodulates data transmitted by infrared.Three-wire sensors....
Yes I agree.Virtually none of that has anything to do with the receiver in question. It demodulates data transmitted by infrared.
Unless you are the author of the posted text, you are expected to cite the source.
| Thread starter | Similar threads | Forum | Replies | Date |
| A | Shed a light on this wires gatherer in 400/40 Watt rice cooker | Technical Repair | 1 | |
| B | Wire Strippers | General Electronics Chat | 23 | |
How to drive a 5 wires stepper motor without Arduino ? | Digital Design | 17 | |
| A | USA 240V three wire L1, L2 and a Ground | Power Electronics | 22 | |
wire wrap pins | Marketplace | 10 |
