No not as yet, they have to arrive which they will soon, but worried about what MikeML said:Yesterday I was reading the datasheet for that type of LEDs, an those 2 voltages -at least in that model- where for the typical voltage and maximum voltage drop; not the minimum and maximum.
So I was thinking, if 2.2v is the typical voltage, 12v for the 5 LEDs in series you had originally intended would come to 2.4v each; which shouldn't be too dim.
Have you given it a try yet?
Now, if you hook the four LEDs to a 12V high-current constant-voltage power supply, you will instantly vaporize them. You need to put a resistor between the 12V supply, and the four LEDs to prevent that!
Unfortunately, the specific value of resistance required to limit the current through the LEDs (think of ballast in the context of a florescent tube) is dependent on the exact total of the forward voltage drops of the LEDs. This is not the preferred way of doing this.
It is much easier to buy a LED driver constant-current type of power supply, which has a pot on it to set the max. allowed current for your specific LEDs, and the power supply voltage magically takes care of itself with no resistor required...
