how to use UART in circuit design?
35,207
UART is still being used on micros because:
1) it is easy to implement in hardware
2) historical and legacy reasons, backward compatibility.
USB needs much more than hardware to implement. It requires a lot of software overhead to implement the USB protocol. You will not find USB in low end MCUs.
UART and USB are two completely different things.
There is such a thing as a UART-to-USB bridge, such as Silicon Labs CP2102 which can be used to connect an MCU with UART to a host computer USB.
However, the PC sees the MCU as a UART COM port, not a USB device.
35,207
cmartinez
Joined Jan 17, 2007
8,862
In case you want to know, the best chipset for UART to USB conversion is manufactured by FTDI, its drivers are far better and more reliable than prolific, for instance.
kai hiwatari
Joined Feb 20, 2015
3
thanks, it helped me alot
