USB UART Circuit with Protection
Aashram
Joined Nov 17, 2014
10
Hi
I am trying to make a circuit for USB to UART. For that I am using:
FTDI230X: http://www.mouser.de/ProductDetail/FTDI/FT230XS-R/?qs=sGAEpiMZZMvVkErl6zY%2bqR%2b6A%2bu/1HB5
WE TVS Diode Array 824011: http://www.mouser.de/ProductDetail/...=sGAEpiMZZMsgNhPy3wz0s7JC25wFgpK3tUoJ3YHBnr0=
Common Mode Chokes / Filters WE: http://www.mouser.de/ProductDetail/...qnvsilMhY5xdooAk%2bM7YdNaABXylUlITcfstZkF/w==
And Ferrite for VBUS: http://www.mouser.de/ProductDetail/Wurth-Electronics/742792641/?qs=5twSNpOB8IBOTWTDxxe6GA==
I have attached the rough schematic.
Am I doing right?
Where should I connect VBUS ( to VCC or VCCIO or 3V3OUT)?
The other pins in FTDI I have marked as NC, Is this OK?
Do I need to add capacitor also in this design?
Thank you all.
DickCappels
Joined Aug 21, 2008
10,661
It looks good but you will need to add bypass capacitors like those shown in the drawing at the page to which ScottWant's link in post #2 takes you. Those components in series with the D+ and D- lines to the chip should not be inductors. If the FTDI datasheet does not explicitly say that damping resistors are not needed on the D+ and D- lines you should put them in series of the lines where what looks like inductors are drawn.
dendad
Joined Feb 20, 2016
4,635
The links work for me, but if you move the mouse, it changes. I don't like that sort of web site.
Here is one part..
TDx01D232H http://www.mornsun-power.com/uploads/pdf/TDx01D232H.pdf
And a dual one...
http://www.mornsun-power.com/uploads/pdf/TDx02D232H.pdf
RS485... http://www.mornsun-power.com/uploads/pdf/TDx01D485.pdf low speed
http://www.mornsun-power.com/uploads/pdf/TDHx01D485H.pdf high speed
http://www.mornsun-power.com/uploads/pdf/TD5(3)21D485H-A.pdf Auto switching.
There are quite a few more too.
DickCappels
Joined Aug 21, 2008
10,661
The links to the pdf files all work. Those are pretty nice looking modules! I didn't realise that you could buy them ready-made.
Aashram
Joined Nov 17, 2014
10
Thnaks. The module looks good.
But I have made some progress with my design.
The previous doubt were very well clarified. Thankyou DickCappels
I want to protect TXD and RXD. Can I used the same circuit as I used for D+ and D-?
Do I need to use LC filter for TXD and RXD or only TVS diode will suffice?
