How to use SN74LS48 decoder to drive CK- 7 Segment
Jasper Gabriel
Joined Mar 23, 2016
11
How do you use the decoder? I mean I tried connecting the vcc and ground to its respective connections.
Connected rbi rbo and lt to supply 5 v
And connected outputs to 7 seg.
But it doesnt work. Tried using switches and connecting the input pins to ground or supply. Had no problems in 7447.
P.S. already checked data sheet but I just dont understand how to make it work.
Jasper Gabriel
Joined Mar 23, 2016
11
Or is it possibile that I use CA? Nah used vom to check. Connected negative tester to gnd of 7 seg and used the positive to check the segments.
When i connect lt to ground the seg all lights up.
JoeJester
Joined Apr 26, 2005
4,390
Did you look at the truth tables for each?
Look and see what you need or can use to make it work properly with what you have.
Jasper Gabriel
Joined Mar 23, 2016
11
You need common anode displays for use with the 74LS47 and common cathode displays for use with the 74LS48.
Les.
Yes I used 7448 with common cathode.
I've figured out what's wrong. I need to supply 5 V to pin 3 and 4 ONLY. (LT and RBO) while I need to connect pin 5 (RBI) to the ground. It worked as it is supposed to now.
I don't really understand. In Common anode/7447 applying 5 V to pins 3-5 would work.
Anyway thanks!
