hey.. i wanted to use the ldr on high power circuit (i.e. 150 watt bulb running at 220volt ac supply) but i was unable to do so. (reason for using ldr is that i want to control the illumination of a room i.e. higher the light already present in the room, the lower will be the ilumination of bulb connected to it. making total illumination in the room constant)
i tried many different components but didnt find suitable component that would do the trick for me.
somebody suggested me to use phototransistor with an SCR, but i dont know if it will work the same way or it will just switch ON and OFF the output (which i dont want).
