Hy Paulo,
The problems you have been experiencing are quite normal.
The core cause of the distortion on your waveform is the layout on the bread board, as has already been stated. And, of course, your probe not being set up didn't help, also as has already been stated.
I am not sure if you know this, but the schematics that you see for a circuit are only theoretical- they do not represent the actual circuit of the physical build. And as the frequency increases this effect becomes more significant.
The reason for this is that components, wires and connectors etc are not perfect. Even a simple piece of wire has capacitance and inductance and at a high frequency a resistor can become an inductor. For a 47 Ohm resistor the frequency is around 200Mhz.
So the message is that if you are building high frequency circuits you need to use a ground plane, short leads, high frequency components and short relatively thick conductors.
I notice that you fitted a decoupling capacitor across the supply lines of the 5MHz oscillator but, if I read your image correctly, the capacitor was not suitable and would provide no decoupling, as you found.
For decoupling at high frequencies you invariably need to use a ceramic capacitor of 10nF or 1nF, while 100nF, 1uF and 22uF ceramic capacitors are good for other applications depending on the frequency and power involved. The best dialectic, taking into account all factors is X7R and you need to select a capacitor suitable for high frequencies. Some of the surface mount multi-layer capacitors are not too good, for many reasons.
The other thing to bear in mind is that what you see on an oscilloscope screen is not necessarily what is going on in the circuit you are measuring.
For example a standard 6 inch oscilloscope probe earth lead can introduce ringing and distortion and the capacitance and insductance of the oscilloscope probe will possibly affect the circuit being measured.
So after all that what is the solution.
(1) Forget about breadboards for high frequency work
(2) Instead build your HF circuits on a piece of copper-clad fiberglass board.
(3) Decouple the power line input with ceramic capacitors for high frequency and electrolytic capacitors of around 47Uf for low frequencies.
(4) Make all leads as short as possible,
(5) Set up your probe for a flat response using a known good square wave
(6) Use as short an earth lead on your scope probe as possible.
The above only scratches the surface of building high frequency circuits and monitoring the wave forms on high frequency circuits.
End of lecture.
phonic
End of lecture.
phonic
