How to Stabilize the Output Voltage Using a OP AMP Comparator Circuit and Draw Current(1A) from it?
Debraj Das 3
Joined Mar 11, 2019
5
I wanted to design a power supply which can supply about 1A at (+-12v) to (+-15v)so I chose to use the regulator IC like 7812 and 7912 and now I have heard that we can actually use a comparator circuit to stabilize this output voltage further but I don't know how to do it.Can Anyone tell me how to get more stabilization using comparator and actually how much current can I draw from this circuit without dropping the output voltage and it will be better if someone can tell me to how to draw about 1A current from this comparator circuit without dropping the voltage?
Here is the basic structure of my Power Supply Circuit
A 24-0-24 2A transformer➡ Bridge Rectifier➡C Filter➡Regulator IC(7812 & 7912)➡Comparator Circuit➡Stabilized (+-12v)to(+-15v) 1A output
I want to know about this Comparator Circuit
38,948
And where did you hear that?
You seem to be confusing two different power supply techniques, linear and switching.
The linear approach uses a linear regulator, such as the 7812 or 7813, to provide a regulated DC voltage.
The switching approach uses switching devices, such as a comparator, in conjunction with other switching devices, to generate a DC output voltage.
I don't see any obvious way to use a comparator to help regulate the output of a linear regulator.
(And I don't see why you would want to since those linear regulators regulate the output voltage very well.)
I suggest you go to wherever you "heard" that to find out what they are talking about.
DickCappels
Joined Aug 21, 2008
10,661
Perhaps you are looking for something like this? Tracking voltage regulator.
If you look around you might be able to find and LM317 serving as the output stage for an op-amp stabilized opamp.
By the way, comparators are different fromopamps with the same schematic diagram.
danadak
Joined Mar 10, 2018
4,057
Debraj Das 3
Joined Mar 11, 2019
5
Debraj Das 3
Joined Mar 11, 2019
5
Sorry Sir,but I too am confused how to do that that's why I have came here and I too am not seeing any way to use comparator as a voltage regulator...and I have heard this from one of my ex-teacher who have retired now so there is no way to contact him that's why I came to here and posted this thread...can u please explain me what is this switching approach u talked about actually I am just started learning electronics that's why I don't have much knowledge...
ericgibbs
Joined Jan 29, 2010
21,649
That reference states it discusses both linear and switching regulators, but I only see a discussion of linear.
hi,
I noticed that too, anyway I considered it would easier for the TS to get savvy on Linear before reading up on SMPS.
E
This PDF should give him an insight into SMPS
