How to solder SIM800 radio module?
eem2am
Joined Jul 22, 2012
40
We wish to hand solder the SIM800 RF module...(seen here on pages 15 and 16)
https://www.simcom.com/service-844.html
There is a 0.4mm gap between the pads, though due to the castellated side pads, the solder splurges out and shorts between the pads when you are soldering it. You cannot use a fine tip iron as it doesnt heap up the pad and connection enough.
This is the soldering station we have..
https://kurtzersa.com/products/elec...ols/soldering-desolderingstations/i-con-1-mk2
This was the soldering tip we used, but it was giving shorts between pins....
https://ersashop.com/weco(====)/app...ail&m_ca_bd_GV_ITMGUID=051MciB67joYcIpE1UvH20
