Hi All,
I'm working on my fist pcb design and encountering a design issue I'm not sure how to solve.
On the board I will use an ATmega328 as a processor.
I will need the RX and TX pins to communicate with a break outboard I want to fix to the PCB.
I also need the RX and TX pin to upload my firmware to the ATmega (connected to some pins/headers)
On a breadboard I would just reconnect wires as required, on the PCB they will be fixed.
How would I go about this?
Do I use jumpers so I can connect the one to the other but also connect to an external signal?
Thanks,
Thanks,
