The selection of MOSFET depends upon various parameters in which one important parameter is Vds.
Max drain to source voltage is the rating given to the parts ability to block voltage applied to it when it is off. A good rule of thumb is to choose a part whose voltage rating is twice that of the expected voltage applied to the drain. The reasoning behind this is that short voltage spikes well above the input voltage are common in electrical systems where switching MOSFETs are present.
So if I have a DC voltage of 350V from the DC link, according to what I have understood from the above, I have to choose a mosfet whose Vds_max is twice the voltage applied to drain which is 350V*2=700V Vds max. Can anybody tell me if it's the correct way to do?
