How to run LED ON 1kHz signal.
Audioguru
Joined Dec 20, 2007
11,248
The Cmos 555 has a typical output high current of only 2ma when its supply is 3.6V.
Some ICs will have less output current and the current is less when the battery voltage runs down.
Then the LED will be extremely dim.
Wendy
Joined Mar 24, 2008
23,830
You could always go with another AA, or 9V. The heat build up is a valid point.
Look for one of the current LED flashlights with the 3 AAA adapters. You need the extra volt.
Check the specs of this specific CMOS 555, it can go to 100ma down to 3V. I was suprised when I saw it. Here is the datasheet.
iamspook
Joined Aug 6, 2008
27
LEDs are non-linear current-driven devices. Trying to modulate that beast
as a sine-wave will be tricky! You might be able to approximate it by using
the square wave as input to charge a cap with the right CR time constant
so that you get something that looks like a triangle wave. Prototype it
or simulate it first?
Wendy
Joined Mar 24, 2008
23,830
Right now we need to figure out how to a> feed a LED that drops between 3.2 to 3.8 volts 20ma with a 3.6V battery or b> get a small battery that won't cause a lot of waste heat from excessive voltage. Once these are solved then we can move on.
Just from what the OP has said I think we can PWM modulate the 555 with a sine wave, but first things first. What ever scheme is used space it tight.
kvsingh21
Joined Apr 15, 2008
63
I am happy with LED modulation circuit acheived thanks to you and other guys on the forum. I am going to stick with square wave, and the LED is dropping 3.15V across it, which is fine. I used 2 x 12V batteries in series to do so. I have decided to use a heat sink to solve the heat issue.
Wendy
Joined Mar 24, 2008
23,830
OK, cool. I suspect some of your distand issue could be an LED that is barely turning on though. If you decide to try the experiment you might try an extra cell and see if that extends the distance. Hope you're having fun, I am.
