How to rout the 220V AC trace on PCB
Md_Yusuf
Joined Aug 2, 2022
23
Hi, I am designing a PCB in which there is 220V AC voltage involved which enters through the power inlet connector then this signal goes to SMPS from where this signal converts to 12V DC signal and then this signal converts to other required low voltage but the problem is that I don't have idea about the routing of AC voltage like how to give cut out and isolation from other low voltage please give me idea about this that would be highly appreciable thank you
Ian0
Joined Aug 7, 2020
13,306
If it is Class I then it has to be at least 3mm from any low-voltage tracks, if it is Class II then 5mm. (This varies with the tracking index of the pcb material and the "pollution degree" i.e. how much dirt is likely to accumulate on the pcb during its lifetime, and how conductive that dirt may be. You will find tables for all the distance in EN60335-1.
Make sure that it is fused for the current carrying capacity of the tracks.
If the incoming mains cable is soldered to the board then it needs additional mechanical support in case of breakage of the solder joint.
Externet
Joined Nov 29, 2005
2,680
Hi.
Route them near an edge of board, away from any other traces, grouped with all AC components as fuses, chokes, transformers, transzorbs. Stay away from small signals traces. Etch warnings for that area.
Md_Yusuf
Joined Aug 2, 2022
23
Thanks for the reply also how much the approximate trace thickness would be on PCB
Ian0
Joined Aug 7, 2020
13,306
28,485
Another method is learning by example. Borrow some scrap power supply PCboards and observe the spacings that are used for the mains level traces. This is in addition to the good advice posted so far. Failed product boards should be easy to get.
Ian0
Joined Aug 7, 2020
13,306
Unless they are failed far-Eastern power supplies which have insufficient mains clearance/creepage!
