How to regulate voltage using TIP122
kithul godage Vijitha
Joined Aug 8, 2017
7
Need regulation accuracy, maximum current, maximum input voltage.
What does it do below 14v?
actually I hope to use this to Alternator, for charge the lead acid batteries. then 200Ah batteries are connect as parallel so I want to charge the batteries without over charging. because I want regulate alternator output, using TIP122.
Joined Aug 8, 2017
7
How is the input V/I?
How is the Vout?
Input voltage is not constant value. it will change according to RPM of alternator. maximum current 80A.
cmartinez
Joined Jan 17, 2007
8,860
How many TIP122 do you have with you? Because a single of those transistors is only capable of handling 5A at most. And that's under ideal conditions. You'd end up with a rather inefficient circuit with numerous components to accomplish what you want.
There are other options out there, such as MOSFETS. Is the use of TIP122 for your application a must?
ScottWang
Joined Aug 23, 2012
7,505
The circuit can't be that simple, because you want to build the batteries charger with high current.
Joined Aug 8, 2017
7
it doesn't matter. I want to just create a circuit for apply Alternator. I haven't idea how to use MOSFET for regulate the voltage. please send me your idea. It will more helpful to me.
ScottWang
Joined Aug 23, 2012
7,505
Voltage regulator for Alternator:
Vin = input voltage unknown (range?).
Iin = input current 80A.
Vout = input voltage unknown (14V?).
Iout max = 80A * eff% = ? A (80A?)
12V Batteries:
Iout max = 200Ah
Vout = 14V
dl324
Joined Mar 30, 2015
18,467
14V is not optimum for charging 12V lead acid batteries, nor is charging them in parallel.
Go to batteryuniversity.com and study the requirements before you try to build a charger. You'll find that you need a timer and multiple voltages.
