Can someone please explain how to know which pins are for the primary coil, the flyback coil and the HV ground.
I have measured the resistance between all the pins and get either 1.5 or 0.5 ohms and nothing in between.
Also, using the method where a 24v supply is connected, I was unable to find the HV ground.
I have attached the schematic bellow.
Thank You
Thank You
