How to protect ADC of microcontroller from high voltages?
Atagkh
Joined Sep 8, 2018
20
I am using a micro controller for my project and I need to read a voltage with its ADC. Each ADC can handle 3v, so my question is how to protect the ADC from high voltage spikes in the circuit? I am using op-amps to map the voltage between 0-3v, however I need to make sure that the voltage is not going above 3v. Is it possible to do it with Zener diode? If yes, could you please suggest a design for me?
I appreciate your help.
Regards,
Ata
ericgibbs
Joined Jan 29, 2010
21,567
hi,
The datasheet for the TL084 shows the Vout will only reach approx Vsup -1.5v, so a 5Vsup will swing to 3.5V.
You could add a series resistor and say a 3.3Vzener on the Vout of the OPA.
E
Atagkh
Joined Sep 8, 2018
20
Thanks for the responses. I think I misunderstood the question before. The supply voltage for my op-amp is +Vcc=15v and -Vcc=-9v.
What I want to do is that I want to give the output of my op-amps, which Ideally should be between 0v and 3v, to my ADC. I use resistors to limit the output of my op-amp in the above region but I want to have some sort of protection to make sure that if there are spikes in my circuit and output of my op-amp reaches for instance to 5v, the ADC would not burn! and the voltage is limited to 3v. I know that Zener diodes can limit the voltage but the problem is that I don't know how to use Zener diode so that when the voltage is under Vz, it goes into the ADC without any voltage drop, so that if the voltage is under 3v, I can read it correctly and if it goes above 3v, it is limited.
ericgibbs
Joined Jan 29, 2010
21,567
hi,
The resistor is in series with the OPA vout to the ADC input pin, and the 3.3v Zener from the ADC input pin to 0V.
A 330R resistor should be OK.
Do you need a diagram.?
E
ebp
Joined Feb 8, 2018
2,332
In general, zeners are very poor devices for protecting analog inputs if the maximum allowable voltage is close to the full-scale voltage.
Up to something between about 5 and 6 volts, the devices we call zener diodes are in fact "true" zener diodes. The breakdown mechanism is quite different from that of diodes above that range which are actually avalanche diodes, even though we usually call them zeners.
The reverse breakdown mechanism of true zener diodes means that they begin to conduct current at a voltage well below their nominal. If the relationship between current and voltage is graphed, the curve have a rounded "knee" instead of a nice clean sharp 90 degree angle. Add to that the normal tolerance of a zener, and it really becomes a problem.
For example, the MMSZ5226B is nominally a 3.3 V device. It is characterized at 20 milliamps and the breakdown voltage range can be from 3.14 to 3.47 V. 3.47 V is certainly within the acceptable maximum voltage range for most ICs operating on 3.3 V - usually the absolute maximum is something around half a volt above the positive supply rail. But the 3.14 is a problem, and remember it is specified at 20 mA. There is a spec for "reverse leakage current" - 25 µA at 1 volt. But nothing numerically spec'd at say 2.5 V.
You must use a series resistor to limit the current from the amplifier and through the zener. Suppose you choose 1000 ohms. At the 25 µA leakage current, that equates to 25 mV of error, or about 0.83% of full scale for the ADC. That's not too terrible for an 8 bit ADC, but it amounts to over 8 counts for a 10 bit and 34 counts for a 12 bit. And again, we don't know what to expect at 2 or 3 volts.
It is hard to find curves for zeners that are very revealing at low currents. About all you see in most datasheets is a "hook" near the X axis.
Generally the lower the power rating of a zener, the better behaved it is for this sort of application. The 52xx series is rated for half a watt. There are some 250 mW types that are better, but I can't recall the series.
With many devices it is perfectly acceptable to use the internal protection diodes, but the datasheet must be reviewed carefully. The allowable current, assuming it is specified (and it usually is) can range from 2 mA to 20 mA or even 50 mA, with caveats for how many inputs can be overdriven. Again, a current limiting resistor is essential. While this may protect the inputs from damage, it may be completely unacceptable in terms of operation. I have used ADCs where all channels would be scrambled if any single channel voltage exceeded the positive supply rail by more than (as I recall) about 100 mV - far below a voltage that would be damaging. That made things very difficult.
Schottky diodes, very carefully chosen for low reverse leakage characteristics, can be used to clamp signals to the positive supply rail (resistor required, as always) to keep the ICs internal protection diodes from conducting significant current, but this still may not fix problems with misoperation.
There are techniques that can be used to clamp the output of op amps, but they are not simple either if the clamping voltage needs to be precise. You should be able to find info on such circuits on the web at sites like Analog Devices and Texas Instruments.
If you have lots of money, Analog Devices makes some very nice clamping amps.
While they are by no means perfect, rail-to-rail op amps run from the same supply voltage as the ADC can work reasonably well, but they never go truly to the rails so a bit of range can be lost at the bottom and top.
I have an abhorrence for tying to do precision analog at 3 volts. It is not impossible, just much more difficult than even 5 V.
Atagkh
Joined Sep 8, 2018
20
Thanks for your detailed explanation.
What do you think about using opto couplers? Are they useful for this application? Or they would just transfer the voltage that might be more than 3v and hence burn the ADC?
ebp
Joined Feb 8, 2018
2,332
Optocouplers aren't useful for any sort of analog circuitry that requires any sort of accuracy, except for those designed specifically for analog applications. Even then, they require op amps to complete the circuit. They are quite expensive. The CNR200 or HCNR200 is a typical analog optocoupler that does work very well.
Probably the least expensive solution is to use rail-to-rail op amps and, if necessary, run them on a "split" power supply. If you used supplies of say -0.5 V and +3.3 V, you would likely get a full 0 to 3 volt swing at the input to your ADC without exceeding the allowable limits. If you don't need to go right to zero or to 3.0 V, then you could just use 0 V and 3 V for the supplies. Of course you may still have to protect the amps' inputs from excessive voltage. Depending on the circuitry, that may be just as difficult as protecting the ADC inputs or considerably easier. With non-inverting amplifiers,using a resistor and relying on the protection diodes in the amp can work well - but always check the spec's to see what is allowable for the input diodes.
danadak
Joined Mar 10, 2018
4,057
Look at UP datasheet for input Z considerations of the A/D. Some
parts adding series R causes the sampling front end of the A/D not
to settle as fast as you think it is just based on conversion time speced
for A/D.
Regards, Dana.
Atagkh
Joined Sep 8, 2018
20
hi,
E
The maximum input that I can give to the ADC is 3V, so I want to use the 1N5221B, which has Vz=2.52V, I use 300R resistor with op-amp. however I don't want any voltage drop below 2.52V. I mean when I try to read for instance 2V, there is a voltage drop and I only read 1.75V. What should I do to solve this issue?
OBW0549
Joined Mar 2, 2015
3,565
What should you do? Do what @ebp and @Sensacell both suggested: use a diode clamp to Vdd.
The reason low-voltage Zener diodes are a very poor choice for this is exactly as @ebp described above (emphasis added):
That is why you're having this problem: your Zener diode is conducting significant current at voltages well below its rated voltage, and this current is causing the voltage drop you're observing.
Stop trying to do things the wrong way, and try doing them the right way.
Atagkh
Joined Sep 8, 2018
20
Thanks for the answer! but if you are not in the mood to answer one's question then don't! You have a tone as if you are talking to a stupid person! That is not nice dude!
BobaMosfet
Joined Jul 1, 2009
2,211
Cart before the horse. Instead, try this (since you said your OpAmp will put in in the 0-3V range)- filter your signal input into your OpAmp to remove spikes. Inductors, Capacitors, and Resistors in combination are _amazing_ at solving noise issues without dealing with 'knees' and quiescent voltage losses just to make a component work. After that, put a series resistor into your ADC from the OpAmp to limit the current to 1mA. Your ADC should be pretty happy at this point.
ebp
Joined Feb 8, 2018
2,332
"After that, put a series resistor into your ADC from the OpAmp to limit the current to 1mA. Your ADC should be pretty happy at this point."
Maybe. Maybe not.
The ADC will almost certainly be protected against damage. However, current injection can be a problem in that it can cause error on inputs that aren't being overdriven.
To quote myself from number nine ... number nine ... number nine (sorry, White Album nostalgia)
"With many devices it is perfectly acceptable to use the internal protection diodes, but the datasheet must be reviewed carefully. The allowable current, assuming it is specified (and it usually is) can range from 2 mA to 20 mA or even 50 mA, with caveats for how many inputs can be overdriven. Again, a current limiting resistor is essential. While this may protect the inputs from damage, it may be completely unacceptable in terms of operation. I have used ADCs where all channels would be scrambled if any single channel voltage exceeded the positive supply rail by more than (as I recall) about 100 mV - far below a voltage that would be damaging. That made things very difficult."
ebeowulf17
Joined Aug 12, 2014
3,307
From what I've read, it sounds like the advice of @ebp , @Sensacell , and @OBW0549 should meet your needs.
However, if you want a clamping system with an even harder, sharper limit so you can get unaltered signal closer tip your clamping voltage, and also set your clamping voltage wherever you want, there's a thread discussing several approaches here:
https://forum.allaboutcircuits.com/threads/op-amp-voltage-clipper-issue.145884/#post-1245217
I haven't built any of the circuits in the thread, but I experimented quite a bit with simulations of the circuit I shared in post 11 of that thread, and I'm pretty confident in it.
