Hi Guys,
I have two HP server power supplies rated at 12V/75A at 115V, or 12V/100A at 240V that I have been using in series as input to a boost style RC battery charger. I was careful to isolate the DC ground in one of them and they have been working fine together charging my 36V e-bike battery pack at 6A with no sparks or shocks at all.
Now I would like to use them to build a lab style bench power supply using two of these 50V/15A Chinese-made Programmable Power Supply Modules As I understand it, real bench supplies typically have two or sometimes three separate built-in supplies wired in a master-slave arrangement where the master is configured for CV and the slave(s) are configured for CC. My question is, other than the series output connections, are there any other connections between the two supplies that should be made? For example, is it necessary to design a circuit to power off both supplies in the event that one should fail or drop its voltage below a set point in order to protect the device to which they are attached? I'm told that boost chargers typically don't like sudden drops in input voltage.
Also how should I fuse them given that the control modules can only deliver 15 amps but the supplies are capable of much higher currents? I would like to make this device as safe as possible.
Thanks!
Thanks!
