My Arduino Nano project contains two 5V servos (MG90S) of which the datasheet does not mention current, a 5V LCD with a max current of 8mA, a 5V dc motor in a waterpump with max current 200mA and some sensors. Can I just power the sensors from the nano and do I need a separate 5V supply with like 2 Amps to power this?
The servos and pump will only be rotating for a few seconds per hour. And it is possible not to rotate them at the same time if that helps.
I hope someone can tell me how to properly power my idea. THANKS A LOT!
