How to Power DisplayPort Device?
Muncle
Joined Oct 3, 2019
I'm building a custom DP converter but need to power via DP. How is one supposed to power the device when DP cables are inherently lacking pin 20 (DP_PWR) connection?
jpanhalt
Joined Jan 18, 2008
11,087
What's "DP." Please write out abbreviations on first use, unless extremely common.
20 pin? Do you have a 20-pin graphical display? What type?
Muncle
Joined Oct 3, 2019
Hint is in the title.
This is for driving a custom HDR converter. Just need to be able to supply power over DP cable and needs mini DP on one end. I hear a lot of rumors about finding "bad" cables that have pin 20 connection but I can't find any that are intentionally built this way. FYI these are referred to as "bad" because they will cause power conflicts between source and sink but it's exactly what I need.
