Hi again,
I want to make bode plot in lt spice for low pass filter....
but how??
but how??
Its the way or type of sweep for your simulation, most of the time I use Linear(lin) the spice command is like this "ac oct 30 10 300" the first word "ac" says this is an ac analysis ,"oct" means the type of sweep ,first number "30" is the number of points for sweep, second number "10" is the starting frequency and the last number is "300" the end frequency where the simulation ends. You can set these parameters using Edit Simulation Command window just right click over the spice command.what is this no. of decade or octave??
Please elaborate this..."oct" means the type of sweep ,first number "30" is the number of points for sweep
what the diff.in linear than other ...Here I have used a the Linear option to plot the graph so the voltage across the capacitor is plotted on the Y axis,
In linear option the graph will be plotted using voltage or current in the circuit linearly.what the diff.in linear than other ...
