How to NI Multisim
Status
Not open for further replies.
shteii01
Joined Feb 19, 2010
4,644
Thank You for amazing help! I will do step by step. My inctructor tell what I can choose by myself frequency steps.
But I have one problem at the beginning. I created schema like Yours, I add 20mV ( I try and 20, 100 V ) in AC voltage, but osicilograms showing something wrong.. I attachement some picture of it.
What can be problem at ?
VD1 is the problem.
Also all the parts I was using were selected just to show my point.
Do you have an actual list of the parts? Real parts!
rio7
Joined Jan 1, 2015
40
VD1 is the problem.
How can I solved it ?
No, my inctructor tell what I have must by myself search or find it on internet all parts. ( I really don't know why ? ), becouse we don't created in real life audio amplifier! We just simulated on NI Multisim and whats all. We must got oscilograms and make same counting.
shteii01
Joined Feb 19, 2010
4,644
Since your instructor did not give you list of parts, this tells me that you have a Design Assignment.
You were given list of design requirements/parameters:
P(out)= 2W
R(load/strain/workload) = 12Ω
Uin = 20mV
F = 300 Hz to 7 kHz
Rin = 2 kΩ
M <= 3dB
In this list there is the input: 20 mV at frequencies 300 Hz to 7 kHz.
Output: load resistor of 12 Ohm and maximum power at this resistor of 2 Watts.
Circuit behavior: input resistance 2 kOhm, M less or equal to 3 dB (I am not sure what M is).
It is your job to design the circuit.
Stop wasting time. Start designing.
rio7
Joined Jan 1, 2015
40
P(out)= 2W
Uin = 20mV
F = 300 Hz to 7 kHz
Rin = 2 kΩ
M <= 3dB
But I already created this schema and from it I need oscilograms. Or I do something wrong ? What first of all I should do right now ?
38,933
If you already have the circuit then why are you saying you don't know how to do the PNP transistors? :confused:
rio7
Joined Jan 1, 2015
40
No, right now Mr. Shteii01 tell me about this! I have just problem with Multisim program and arrow's!
Right now the schema is created right in Multisim, but now I have problems with oscilograms. ( Few post back )
kubeek
Joined Sep 20, 2005
5,796
P(out)= 2W
Uin = 20mV
F = 300 Hz to 7 kHz
Rin = 2 kΩ
M <= 3dB
Those are the parameters of a circuit you are supposed to design, am I right?
My guess is that rio7 was given a circuit and a homework to find out the values.
Status
