How to measure very low resistances?
Ian0
Joined Aug 7, 2020
13,278
I used to measure cable resistance (to check that it was really copper and had the correct cross sectional area)
I used a fixed voltage power supply and a power resistor which I had previously measured accurately. The power resistor in question was my audio dummy load.
MikeA
Joined Jan 20, 2013
450
You'd be surprised!
A 60mV/60A shunt has a resistance of 1m ohm.
You only need 1.2uH of inductance to be 10% out at 60Hz.
To be perfectly pedantic, it won't be a different resistance, it will be a different impedance.
Interesting. I haven't come across inductance in spec sheets for current shunts.
These sell for $100+ a piece: https://riedon.com/media/pdf/RSJ.pdf
It does say "Non-inductive Metal Element". So no inductance at any frequency?
