How to measure device output that is an "mA" output?
MikeA
Joined Jan 20, 2013
450
I have a device that has an analog output that I would like to measure it with a 5v Arduino. The output is rated 5-50mA.
How would one go about measuring current? A resistor across the terminals and measure voltage across the resistor? Am I on the right track? :confused:
MikeA
Joined Jan 20, 2013
450
That's easy enough. :D
Now I'm just curious why would some devices have voltage outs and some amps outs? What are the ups and downs of using one over the other?
38,855
For that a current-loop (commonly 4-20mA) is often used since it's less sensitive to noise pickup then a voltage signal.
Also the same current can be used to provide power to the remote sensor, so two wires can provide both power and signal.
