You have to open the Pir. Now you'll see 6 connectors.Two are for the power, then the other 2 are for the relay and the last 2 are for, in-case someone wants to alter your connections Check on the instructions that came with the pir and see if you can find the relay connectors. All you do now is to connect the pir to my circuit.hi soda,
thanks for the circuit, but how can i connect PIR motion with that circuit,,
still confused,
We can supply a schematic if you supply some information: supply V for PIR & 555; model # of PIR or output specs; 555 or C555?; LED color? What do you have on hand toward the project?
It would be good if you could show us a pic or circuit of this pir. Don't be shy.supply for pir and timer 555 is 12v
model of pir is pr 14 im not really sure the model because get from friend..
output pir in 4v to 6v... timer 555 led color blue,,
