What is the carrier frequency, and what is the fundamental frequency?Hi there ,
My single phase PWM Inverter does not result Pure sinusoidal, In order to make Sinusoidal Suggest me Filter design Calculation L= C=?
JanardhanView attachment 197172View attachment 197172
I did a trial design assuming 15 kHz carrier and 60 Hz reference sine wave, using a 3-pole Butterworth filter with the corner at 866 Hz. which required a 220 mH inductor. Checking Digi-Key shows that the part is obsolete and out of stock.There is a problem. Doing a passive filter for power applications (50-60 Hz) requires values that are difficult to achieve in practice. What is the frequency of the PWM? Some loads may actually be fine with a PWM signal.
What is the voltage output and what is the max current output?
It will be hard to get a really really pure sine, but you can get close with reasonable effort assuming the PWM pattern is also reasonable.
Also it would be good to know why you need a pure sine, what is the application.
BTW -- before designing a filter you need an adequate specification which you conveniently omitted. Wassup?
One more thing. A passive filter designed for any particular impedance will have a 6dB insertion loss.
Oh what is your nominal DC buss voltage and i assume you are using an H transistor bridge.Dear
MrAl
Thank you .
PWM frequency 2400Hz, Fundamental 50Hz
As my application is to feed current to the grid , Grid does expect a pure sinusoidal current , However I am looking for a (LC) filter design for current to become sinusoidal .I think voltage need not be pure sinusoidal( Pls help I dont know )
I am trying to inject a current of 10Amps from the inverter to the grid by using closed loop DQ0 theory
Thanks in advance
I work it this way that My DC bus voltage not less than (RMS 230*1.414) near around 330(please correct me if it is not the way)Oh what is your nominal DC buss voltage and i assume you are using an H transistor bridge.
I am afraid that is not a good enough description.I work it this way that My DC bus voltage not less than (RMS 230*1.414) near around 330(please correct me if it is not the way)
And Yes it is H bridge with unipolar SPWM
Line tied applications do not tie in when the line goes down, they tie in when the line is active ONLY.I don't know details about my grid because it is very reliable. During the few times it has failed we cheer and have a party in the dark.
1) Do you have a circuit to detect grid failure then it automatically connects your inverter or do you do it manually yourself?
2) When you connect your inverter to the grid, how do you know if an electricity worker has disconnected it so he can work on it then you zap and kill him?
3) If the grid fails and your inverter is powering every home and business in your city then isn't it overloaded?
4) When your inverter is powering the grid and the normal grid power returns then isn't there an explosion?
If you have not already, I strongly suggest you get in contact with whatever organization manages/owns the grid into which you wish to tie. I am inclined to believe that all grid managers have, as mine has, published detailed requirements for equipment that will tie into the grid. Failure to comply with those requirements/regulations can have serious repercussions.Hi there ,
| Thread starter | Similar threads | Forum | Replies | Date |
| A | "Pure" reactive circuits exist only in theory? | General Electronics Chat | 9 | |
| R | Schematic of a battery-powered audio range sinusoidal oscillator | Homework Help | 35 |
