thatoneguy
- Joined Feb 19, 2009
- 6,359
Can you indent your code (Translate tabs to spaces), and most importantly, add comments so the purpose of variables and actions is more clear?
There are a few ways to do it. I have a PIC demo board that uses the old school way of geometric transformations to drawing dots on a LED matrix. It uses two 8 bit ports on a PIC to select the row and column of the LEDS. (the wire coils are connected to the CTMU input for a switch function) I know it's not what you want to do but it shows the basic concept of pixel/image rotation using trig functions.But how to get animation of jumping/rotating letter from video like that?
display("Test "); //message to be display are saved in ram in form of dots this is done with the help of function and pointers
display(char *str) //display is called due to which the char/str point the ascii number of char
int addr;
int z;
while(*str!=0)// the last element of array is null to neglect it this is added
addr = ((int)*str++ - 0x20); // the addr is found from external variable declared in code where all hex value of font are saved then the char ascii value is subtracted from 0x20 and str is incremented for next char value ascii
addr *= 5;// then the addr is multiplied with 5 to get the hex patter of the font i.e. 5x7 stand font
int y=0;
for(z=0;z<5;z++){
leds[z] = Font2[addr+y];// then this font is saved in leds buffer array with loop
y++;
addr = ((int)*str++ - 0x20); // this all do the same with next char
addr *= 5;
int y=0;
for(z=6;z<11;z++){
y++;
addr *= 5;
int y=0;
for(z=12;z<17;z++){
y++;
addr *= 5;
int y=0;
for(z=18;z<23;z++){
y++;
addr *= 5;
int y=0;
for(z=24;z<29;z++){
y++;
addr *= 5;
int y=0;
for(z=30;z<35;z++){
y++;
addr *= 5;
int y=0;
for(z=36;z<41;z++){
y++;
addr *= 5;
int y=0;
for(z=42;z<47;z++){
y++;
addr *= 5;
int y=0;
for(z=48;z<53;z++){
y++;
addr *= 5;
int y=0;
for(z=54;z<59;z++){
y++;
addr *= 5;
int y=0;
for(z=60;z<65;z++){
y++;
addr *= 5;
int y=0;
for(z=65;z<70;z++){
y++;
addr *= 5;
int y=0;
for(z=71;z<76;z++){
y++;
Thread starter | Similar threads | Forum | Replies | Date |
F | LED PWM animation without MCU | Analog & Mixed-Signal Design | 11 | |
E | LED Cube Vertical Animation Failure | Microcontrollers | 8 | |
T | 2 frame 8x8 led matrix animation without microcontroller | Homework Help | 1 | |
A | Sine animation | General Science, Physics & Math | 9 | |
Z | Animation Prob | Homework Help | 0 |
by Jake Hertz
by Duane Benson
by Duane Benson
by Aaron Carman
