How to make an Electric Fence
38,948
I generated a capacitive-discharge fencer circuit (below) that runs directly from mains AC without an isolation transformer and uses the dual-output waste-spark coil for safety isolation on the output.
It, of course, requires using a GFCI outlet and being careful when testing, to avoid electrocution.
28,600
Explain reason?
Certainly, MAX! First, the single coil spark transformer provides a better form factor, and much more convenient terminals for external connections. In addition, there is no second high voltage terminal to cause problems. And in the event that a used coil is not available, it will cost much less than one of those goofy looking dual coil devices.
38,948
That second high voltage terminal is just the other connection to the single output winding.
You would connect it to earth ground when used in a fencer.
Is that a good criteria for what devices to use in an electronic circuit?
MaxHeadRoom
Joined Jul 18, 2013
30,885
The 'second' terminal is used for the ground connection. Also provides isolated secondary.
Very easy to adapt to fence controller, and also very effective, myself. others, and the local herd of deer will attest to that.
I get my used auto parts from a local strip-yourself-wrecker, cost: minimal.!
skeer
Joined Oct 28, 2022
134
My next junkyard visit will result in grabbing at couple of those older coils. Until then though I'm having a difficult time finding working examples using ATV coils (not wasted spark kind).
