What voltage booster?I saw this voltage booster module on the web,
Sorry, I forgot to add photos.What voltage booster?
Likely only if you want to kill something.Can I just connect one wire to the fence and the other to ground?
Yea, I know that and you're right. It needs to be periodically, otherwise you can let the wire if you grab it.Likely only if you want to kill something.
To be safe a electric fencer needs the voltage to be interrupted periodically, such as once a second.
Otherwise it could be lethal.
Yes - that's how it's wired. The capacitance between wire and ground stays charged up between pulses - especially in dry weather. As the stored energy is C.V^2/2 even a few pF stores quite a bit of energyCan I just put one cable into the earth and the other on the fence cable?
They should create a forum for people to learn how to build circuits so they will know how to do it safely.Depending on where you are located you can find a lot of products to do this, for example, in the US:
https://www.tractorsupply.com/tsc/catalog/electric-fencing
But, in any case, the way to do it is to buy commercial products, the complexity of safety related things and all the details of a successful deployment make homebrew very dodgy unless you didn't have to ask this question.
