How to make a car battery charger using a transformer 11.2v
Martiio
Joined Apr 2, 2020
50
I have a transformer 11.2v and around 5A. I would like to use it in order to make a car battery charger.How can I increase the voltage to 14v?
35,268
A transformer rated at 11.2VAC rms under load will output over 15.5V when rectified. Output voltage with no load will be even higher.
I think 5A output is not enough to charge a car battery. I have to check this.
Ramussons
Joined May 3, 2013
1,572
You will need about 14.2 volts to Charge a car battery, 13.8 to keep it in a float condition.
You can use a Boost convertor to raise the voltages, but your current capacity will reduce. 11.2@ 5A = 56 Watts. A convertor with 85% efficiency will bring it down to about 47 watts, and at 14.2 volts the current will be around 3.3 amps.
A dead battery will get some life on a overnight charge at this current, but not likely to be charged to full capacity.
You can make a 13.8 volts float charger to maintain the battery in a charged condition.
Martiio
Joined Apr 2, 2020
50
The transformer is 11.2v after rectified! Sorry that I did not say that detail!
Martiio
Joined Apr 2, 2020
50
To be honest I am not sure if the transformer is more than 5A,because i don't have such a load do measure the maximum of the transformer!
ElectricSpidey
Joined Dec 2, 2017
3,362
A transformer that size will not continue to output 12 volts @ 5 Amps, if it can even produce 5 Amps in the first place.
The voltage output is good for a battery charger...but not enough current for a car battery.
ElectricSpidey
Joined Dec 2, 2017
3,362
Overheating the transformer.
Of course you could get lucky and the voltage would drop low enough that it wouldn't produce that much current.
28,485
OK, here is the solution which will provide some battery charging current. Use a full wave voltage doubler circuit! That will give you about 22 volts no load but it will drop quite a bit with a load. But it will charge the battery, just not in a hurry.
The voltage doubler looks a whole lot like two half-wave rectifier/capacitor circuits in series, both powered by the same transformer connection. And that is what it is, which is why you get twice the voltage at no load. You will need two capacitors of probably 1000 microfarad capacitance, rated at least 15 volts working, to have a bit of safety margin. The diodes will need to be rated for more current than the transformer will deliver, ten amps should be OK for a 5 amp transformer.And for battery charging some sort of current meter is really a good idea.
