How To Lower Amplifier Input Volume
coolyyz321
Joined Mar 17, 2017
90
I have a little issue, I am using the Sure Electronics AA-AB41136 Bluetooth 4.0 Audio Receiver Board aptX +EDR 12 VDC as a bluetooth adapter to lead to Sure Electronics AA-AB32189 2x100W TDA7498 Class-D Amplifier Board. The problem is the input volume is so high coming into the amplifier causing the amplifier cut out at around half volume at even the lowest gain. I have tested this with out the Bluetooth board and have not and a problem with volume being too high at the output. What can I make or do to reduce input volume for the amplifier?
coolyyz321
Joined Mar 17, 2017
90
Yes it is connected to the 3.5mm output of the Bluetooth board and leads to a ground loop isolator with a stereo to mono circuit that I put inside leading to the amplifier. The Bluetooth board is running at 15 volts and the amplifier running at 36.
bertus
Joined Apr 5, 2008
23,042
The 3.5 mm output is for headphones only.
The ouput of that may be to high for the poweramp.
Use the RCA cables instead and see how it behaves then.
Bertus
coolyyz321
Joined Mar 17, 2017
90
It is a little better but it still cuts out at around the same volume but it is better. Can something be made to lower the input power from the Bluetooth board?
bertus
Joined Apr 5, 2008
23,042
Is the distortion also noticable with a headphone on the 3.5 mm output of the bluetooth module?
If so, the input of the bluetooth is to much.
Bertus
sghioto
Joined Dec 31, 2017
8,766
Why are you converting the stereo out of the bluetooth module to mono and what is this circuit? Max supply voltage on the power amp is listed at 32v by the way.
SG
coolyyz321
Joined Mar 17, 2017
90
Since there is a subwoofer on one side and tweeter and midrange I’m the other on a lot of songs parts are cut out because it is playing through the sub channel and vice versa. This seemed to fix the problem. And sorry I miss corrected, I was up late when I wrote the first post I have it at 32 volts on the amp.
