First, read this:Hi everyone,
I have two CSB GP6120 F2 batteries. I accidentally over discharged them. I think I might have damaged it but not sure. Is there any method I can determine it with a multimeter?
Thanks.
A motorcycle (6V) headlamp bulb makes a convenient dummy load so you can check how well the terminal voltage holds up under load.Hi everyone,
Thanks.
Hi Ian,A motorcycle (6V) headlamp bulb makes a convenient dummy load so you can check how well the terminal voltage holds up under load.
Damage can be subtle - a fully charged battery can self discharge in not much more than a week.
You can discharge test with a headlamp bulb but they radiate IR instead of convecting like a resistor, so its easier to set fire to things.
How long was it left over discharged? - they sulphate when flat and it doesn't take much sulphation to kill a fair bit of capacity.Hi Ian,
Right now I'm trying to collect some info on the batteries.Now I'm collecting data for the first battery. Its connected to a GE 4150 6.4V 25W lamp. Initial voltage when I measured was 6.31V. As soon as I connected it dropped to 6.08V. Currently I'm running the stop watch and watching how the voltage drops. After 10min11sec and counting the voltage has dropped to 6.06V now. How do you think its holding?
Figures are readily available for 12V batteries - just halve them for a 6V battery.After 25 mins the voltage is now at 6.01V. I think this one is pretty much ruined
